AirPort Extreme as Router
- AirPort Extreme as Router
12-12-2014 3:00 PM
Just wondering if anyone does this already.
I am looking to replace the Technicolour router which is supplied and use an Airport extreme instead. Will this work?
Would i just plug the modem into the Airport and then would i have to enter my plusnet username and password?
Any help would be appreciated
Message 1 of 6
(1,134 Views)
5 REPLIES 5
Re: AirPort Extreme as Router
12-12-2014 3:03 PM
If the Airport extreme has a WAN port to take the connection from the modem, and allows a connection via PPPoE then it should work.
When you're setting it up you'd need to select PPPoE as the connection type, set your username and password (username@plusdsl.net) and possibly set the VLAN to 101 (not all routers ask for this).
Message 2 of 6
(727 Views)
12-12-2014 3:05 PM
Think you'll find that's only on routers with integral VDSL modems Chris.
Quote and possibly set the VLAN to 101 (not all routers ask for this).
Message 3 of 6
(727 Views)
12-12-2014 3:06 PM
Good point!
Message 4 of 6
(727 Views)
12-12-2014 3:12 PM
yup, I do this and it works fine.
Message 5 of 6
(727 Views)
12-12-2014 3:32 PM
Message 6 of 6
(727 Views)
