After switching from BT to Plusnet DNS servers are still BT?
- After switching from BT to Plusnet DNS servers are...
12-02-2017 6:15 PM
hi
i was just trying to find my what my IP was when i noticed that the DNS servers are BTs?
81.139.57.75 - Hostname None ¦ ISP BT
81.139.57.76 - Hostname None ¦ISP BT
81.139.57.44 - Hostname indnsc135.bt.net ¦ ISP BT
81.139.57.43 - Hostname indnsc134.bt.net ¦ISP BT
Have Openreach messed up and not switched me properly?
thx
Also my IP is Plusnet not BT
Re: After switching from BT to Plusnet DNS servers are still BT?
12-02-2017 6:21 PM
Is that not due to you not using a PN Router and you not changing DNS servers within that router?
12-02-2017 6:24 PM
Hi
this is a brand new router never used before I got Plusnet, and it has been updated and factory rebooted.
12-02-2017 6:31 PM
Which router is it?
12-02-2017 6:31 PM - edited 12-02-2017 6:31 PM
Have you have selected Safeguard as that uses BT's DNS servers
12-02-2017 6:35 PM
Its a Linksys router
and i am NOT using safeguard
12-02-2017 6:36 PM
I'm using a Hub One and the DNS are
Primary DNS: | 212.159.6.9 | cdns01.plus.net |
Secondary DNS: | 212.159.6.10 | cdns02.plus.net |
12-02-2017 9:30 PM - edited 12-02-2017 9:41 PM
I had a strange problem with dns servers when I first moved back from bt, It took weeks to sort itself out.
there was no explanation from plusnet either!
I wouldn't bother reading past the first page... I must of been on me pills!
13-02-2017 6:16 PM
What did you use to find those DNS IP addresses? A router wouldn't usually be configured with 4 DNS servers.
