Advice re Openreach modem
FIXED- Subscribe to RSS Feed
- Advice re Openreach modem
05-02-2019 7:39 PM - edited 06-02-2019 12:01 PM
When I first signed up about 10 years ago, we were supplied with a Netgear WNR1000v3 router and an Openreach modem (an Huawei LOL).
I stopped using the Netgear a while back and I am currently connecting using my Draytek 2860n using ethernet to the Openreach modem.
I believe I can plug the VDSL line into the 2860 and decommision the Openreach modem. Is this a good idea?
I was thinking I might be able to get some line stats from the Draytek which are not available on the Openreach modem.
Fixed! Go to the fix.
Re: Advice re Openreach modem
05-02-2019 8:58 PM
It seems a no brainer to me, ditch the Huawei modem and set the Draytek up as a modem/ router.
05-02-2019 9:02 PM - edited 05-02-2019 9:04 PM
Hi @Advanced,
I'd have gotten rid of the Openreach modem the second you got the Draytek in my opinion (as that router is VDSL compatible from what I can tell).
It's just an extra bit of equipment that could cause a problem, also they're not really supported any longer.
It's worth noting you might need to change some of the settings in your Draytek as I imagine it will be set up in ADSL mode currently (with the OR modem doing the Fibre transmission). The fibre settings are here if you need them.
06-02-2019 11:31 AM
Sorry I'm jumping into here as I'm also looking at advice over the Openreach Modem and my own VDSL Router.. On looking I see the OpenReach Modem isn't needed and no longer supported I've had mine since 2016.. Last year I got a TP Link AC1900 Wireless Gigabit VDSL/ADSL Router VR900 V2, since a V3 has come about.. Should I ditch the OpenReach Modem for my VDSL/ADSL Router VR900?
06-02-2019 1:14 PM
Hi @hst125scorton1, checking online indicates that the router you've mentioned has a build in Modem, so I believe you should be able to set this up without the old Openreach modem.
