Advice needed setting up an FTP server
JeremyP99
on a BT HUB 5 (Have a Hub 6 not yet in place - not sure whether it will make life easier)
I'd like to set up an FTP server on my machine. Sadly I am not smart enough to set up all that needs to be done on the router; have tried Filezilla and Cerberus. Both had settings (eg. services) which do not seem to be accessible on the BT router.
Anyone?
2 REPLIES 2
JeremyP99
Re: Advice needed setting up an FTP server
Nor is anyone else, it would seem. Hey ho.
Champnet
Aspiring Hero
Fixes: 11
Have you tried forwarding creating a new 'Application' on the homehub with Port 21 as the port?
Port 21 is the usual default FTP port.
more info here https://portforward.com/bt/home-hub/
