Activation date today, Fault already...
- Activation date today, Fault already...
12-08-2015 12:24 PM
So my install and activation date is today, sadly Plusnet have messed this one up a bit, my line died yesterday from Sky. And my line came back up today landline calls only My fibre has a fault already. What could be wrong, guy on phone wasn't very knowledgeable felt like blind leading the blind. Anybody who can help please?
Message 1 of 5
(819 Views)
4 REPLIES 4
Re: Activation date today, Fault already...
12-08-2015 6:11 PM
So after a full day of troubleshooting if been told the fault is -"Line no sync with no indicative cause"- what does this mean in lay mans terms please? Thanks
Message 2 of 5
(474 Views)
12-08-2015 6:38 PM
Just means that your openreach modem is unable to communicate with the telephone exchange.
Moving from an LLU provider back on to the BT Network often uncovers a fault initially as the network you are now using was dormant and unused until your line was activated.
The no indicative cause part is just saying that line tests have not found any line fault or problem with the equipment that could be causing the issue.
An engineer will find and resolve the cause of the fault.
You will be ok once it's been fixed, it is almost definitely just a teething problem from one network to another
Message 3 of 5
(474 Views)
13-08-2015 12:21 PM
Looks like there's an engineer booked for today, fingers crossed they can sort this out for you.
Message 4 of 5
(474 Views)
14-08-2015 2:13 PM
Not good. Open reach don't seem to have a clue and plus net are just as confused. Help
Message 5 of 5
(474 Views)
