Activate Router early?
FIXED- Subscribe to RSS Feed
- Re: Activate Router early?
07-08-2019 10:37 AM - edited 07-08-2019 10:38 AM
In all seriousness, our router has arrived and a text says it will be activated Friday. I was wondering if we hook it up now can it be activated early or will it cause problems?
Fixed! Go to the fix.
07-08-2019 11:13 AM
You could always try talking to each other. It's rather an old fashioned means of communication but it still works.
Seriously though I'm afraid that it comes down to Openreach engineer availabilty.
07-08-2019 12:00 PM
Hi @soupbowl
I'm afraid that we are unable to get the service activated earlier than the scheduled date due to our suppliers workload.
Apologies for any inconvenience caused.
Kind Regards,
MoR
07-08-2019 12:02 PM
How about buying a TV aerial so you can watch TV terrestrially?
07-08-2019 12:43 PM
Thanks guys. So the only way I can speed it up is to very quickly qualify as an Openreach engineer and set the ISP connection myself? Drat!
08-08-2019 8:13 AM - edited 08-08-2019 8:21 AM
Sorry to be an overexcited child about this, but it would mean I can remotely work without exceeding my phone's data limit.
Latest event log entry was
PPP LCP Send Termination Request [Failed to authenticate ourselves to peer]
08-08-2019 8:30 AM
Hi @soupbowl
I've made a few manual amendments which should allow a connection to be established.
It may be worth disconnecting the DSL and reconnecting it after a few minutes to force a new session attempt.
Thanks,
MoR
08-08-2019 8:31 AM
08-08-2019 8:35 AM
