Absolutely fuming
- Absolutely fuming
Absolutely fuming
27-10-2018 5:40 PM
Second time calling to discuss (last time “changed channels”) still no improvement this time on hold for over an hour!!! Cannot live chat as nobody available.
No way to complain except live chat (not available!!!!) or call (outrageous wait time!!!!)
Then someone eventually answers and they APPEAR not to hear me. I hear them. My phone works for everyone else.
F U M I N G
Appalling service - NO customer service - poor connection yet paying for a minimum speed.
PLEASE Plusnet. Call me to resolve this. I’m so so so cross.
Re: Absolutely fuming
27-10-2018 5:43 PM
What speed are you getting if you use a wired connection to the router? Does that vary at different times of the day?
28-10-2018 11:30 AM
Hi @AmySales I am sorry to hear that you are experiencing issues with your speed. I have tested the connection and this isn't highlighting any issues and the speed is in sync at 40mbps, the connection also looks to be stable.
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 40.0 Mbps |
Upstream Speed | 10.0 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Estimated Line Length In Metres | 208.4 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Very Good |
Interference Pattern | Not Detected |
Service Impact | No Impact Observed |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-40M Downstream, Retransmission Low - 0.128M-10M Upstream, Retransmission Low |
Time Stamp | 2018-10-15T11:30:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 39.9 Mbps | 39.9 Mbps | 39.9 Mbps |
Up Stream Line Rate | 9.9 Mbps | 10.0 Mbps | 9.9 Mbps |
Up Time | 860.0 Sec | 900.0 Sec | 899.9 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-10-28T10:57:55Z | 2018-10-28T11:12:55Z |
Ingress Code Violation | 4 | 1 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
The issues you are experiencing may well be related to the wireless connection between your router and devices. WiFi is prone to interference and there are many factors that can impact the signal.If changing channels hasn't helped, I'd advise separating the routers' wireless frequencies, I have sent you an email on how to do this.
As @jelv has advised, could you please run a wired speed test to see if you achieve similar results, as if this affecting wired connections also we would need to investigate this further.
Let us know how you get on.
28-10-2018 6:31 PM
However, You have not acknowledged my hold time. Or called as asked.
Please consider this a formal complaint. Someone needs To call me.
I need to discuss
Broadband speed & expectations & contract.
The call wait yesterday.
The fact someone answered (after an hour and a half!) but claimed They couldn’t hear me (this call needs to be listed to) and hung up!
The accessibility of complaints
You have my contact details. After 5.30 Monday - Friday is preferable.
28-10-2018 6:39 PM
I await your call.
28-10-2018 8:03 PM
Hello @AmySales,
Thanks for getting in touch via the forums and I am sincerely sorry for the wait times you have experienced.
I will listen to the call in question and ensure if any feedback is due I will pass this onto the relevant team as this is not the level of service we aim to provide.
I have responded with further via your account here.
29-10-2018 1:04 AM
From the original post:
“minimum guarenteed line speed”
The test you have posted look like they were using WiFi. You need to post the result of a speed test using a wired connection.
29-10-2018 11:50 AM
Please call me to discuss my complaint means to pick up the phone. Not to reply on this forum.
Forgive me if this comes across as rude I am so frustrated and disappointed by this company. It’s hell to deal with. I just need to SPEAK with someone. Monday - Friday after 5.30. Please. I can’t make it any clearer.
29-10-2018 3:01 PM
Hi there.
Unfortunately I'm not currently in a position to arrange a call back for you regarding this after 5:30.
We're happy to help over here, but if you'd like to assistance privately, please feel free to reply via ticket 183987459, or send me a PM.
