About my broadband speed
FIXED- Subscribe to RSS Feed
- Re: About my broadband speed
05-03-2019 9:45 PM
I received this email today
When you signed up for Plusnet Broadband, we gave you an estimated line speed range. Now that your Unlimited Fibre Extra broadband has been up and running for 14 days, we wanted to let you know your line speed as it stands today, as a comparison. | ||||||||||||||
Line speed is dependent on: | ||||||||||||||
Other factors which can affect your speed: | ||||||||||||||
Your current speed is lower than your Minimum Guaranteed Speed. We want you to get the best broadband speed you can, so take a look at our guide and follow the tips to help improve your speed. If that doesn't help, you can report a speed fault and we'll try to improve things for you - please see our faults checkerfor help with this. |
Best wishes,”
The strange thing is that my previous BT was syncing at nearly 70mb down but my Plusnet profile seems to be locked at max 60mb downstream.
20.00 Mbps / 59.16 Mbps 22712 / 60652
My line has not gone through any retraining since switching from BT and I am using the same equipment in the same official BT filtered socket.
Can something be done as suggested in the email from Plusnet?
Regards, Brian
Fixed! Go to the fix.
- Tags:
- Added: I signed up to new speed last month was suppose to pay £23.49 but have been billed for £29.99 when i phoned up to let them know they said they were trying to fix the problem then they let it slip i was still wasn't getting the faster broadband
- can't tell me when it will be fixed why they cant change the billing and send me a refund yeat not doing me proud plusnet.
06-03-2019 10:26 AM
Hi Brian,
I've tested this and you're right, the speed is lower than 60mb/s (only just from our side, but still lower).
Could you get your router into the test socket as shown here and if the speed is still lower than 60mb/s, raise a fault here so we can ask our suppliers to take a look at this for you?
Just let us know when you raise a fault.
Best wishes
Dave
06-03-2019 6:27 PM
Hi Dave,
In master socket but no difference.
Tried to raise ticket using link you gave but getting this error (see attachment) after filling out details.
can you assist?
06-03-2019 6:37 PM
Okay, I’ve now managed to raise the fault, under ticket 188129907
06-03-2019 8:04 PM
Thanks for raising the fault Brian.
I've added a reply to the ticket https://www.plus.net/wizard/?p=view_question&id=188129907
Feel free to give us a nudge over here once you've updated it and we'll be happy to pick it up as soon as we can from over here.
06-03-2019 11:28 PM
Nudge Nudge.... dates added to ticket
06-03-2019 11:40 PM
Latest Speedtest from BTWholesale
07-03-2019 11:22 AM
08-03-2019 10:24 PM
Thank you support peeps 😁 just one more thing, can you let me know if interleaving is on? If it is can I have it turned off?
Cheers,
09-03-2019 12:06 PM
Hi @brisycom,
I've checked and I can confirm that interleaving is currently turned off for your line. Please don't hesitate to get back in touch if there's anything else that you'd like to discuss prior to the engineer visit.
09-03-2019 12:10 PM
Thanks Emily and the rest of support team. You’re all being very helpful and I really do appreciate it 😁😁
09-03-2019 12:16 PM
22-03-2019 7:44 PM
Openreach came out today, rechecked all the wireing in the BT socket and all checked out well but he was puzzled as even he admitted it was looking banded. So he said he would check the cabinet less than 300m away. He rang back shortly after to say that the fibre port I was on was a 70mb one hence the 60mb max connection. He said this wasn’t right and said he would get me changed to a faster one.
About 10 minutes later he calls back to say it was now all changed and the same issue seems to be affecting 50 other connections in the cabinet. BT have been instructed to change the whole card in the cabinet so quite a worth while visit that should also help other people to.
Anyhows i am now syncing at 76mb down and its rock solid.
The Openreach engineer was fantastic and a real credit to his team.
Support can I have a new GEA report for my line to see the shiny new stats please 😁
A Big thank you to everyone who has helped me sort this out. You peeps rock!
23-03-2019 8:32 AM
Hi @brisycom, thanks for getting back to us.
Of course, please see below:
GEA Test Detail | |||
Circuit ID | NA | Service ID | NA |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 76.9 Mbps | ||||
Upstream Speed | 20.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 305.6 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Very Good | ||||
Interference Pattern | Not Detected | ||||
Service Impact | No Impact Observed | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2019-03-22T09:45:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 76.8 Mbps | 76.8 Mbps | 76.8 Mbps |
Up Stream Line Rate | 20.0 Mbps | 20.0 Mbps | 20.0 Mbps |
Up Time | 900.0 Sec | 900.0 Sec | 900.0 Sec |
Retrains | 0.0 | 0.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-03-23T08:02:20.325+00:00 | 2019-03-23T08:17:20.325+00:00 |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 1 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Please let us know if you need any further assistance at all.
23-03-2019 7:41 PM
Thanks Owen
