Ability to Reset Openreach FTTC Broadband DLM Profiles Arrives
- Ability to Reset Openreach FTTC Broadband DLM Prof...
- « Previous
- Next »
Re: Ability to Reset Openreach FTTC Broadband DLM Profiles Arrives
26-07-2018 6:55 PM
26-07-2018 7:03 PM - edited 26-07-2018 7:04 PM
When an IP Profile changes, does it take a while for that speed to be achievable?
SNR is 2.4 now
26-07-2018 7:17 PM
26-07-2018 7:32 PM
- Estimated line speed:
- There's no speed estimate currently held on your account.
- Current line speed:
- 68.6 Mb
27-07-2018 10:42 AM
If your router sync rate are still at 75020k, BT Bras IP Profile should be set at 72.53Mbps and PN Current Line Speed should be set at 72.5 Mb. But check your router stats and run BT Speed Test again to ensure nothing has changed before checking PN Current Line Speed because it might change due to your DLM testing on your line if stable enough 3dB.
27-07-2018 4:53 PM
The lower target SNRM profiles tend to use the "Retransmission High" profile, which results in an IP Profile of about 91% of the sync rate.
27-07-2018 5:01 PM
@ejs u are 100% spot on right due to Retransmission High
30-07-2018 9:09 PM
Connection speed seems to have gotten stuck again, hasn't really changed for a week:
Download speedachieved during the test was - 61.13 Mbps
For your connection, the acceptable range of speedsis 40 Mbps-68.93 Mbps .
Additional Information:
IP Profile for your line is - 68.93 Mbps
30-07-2018 11:25 PM
PN current line speed ?
30-07-2018 11:50 PM
30-07-2018 11:53 PM - edited 30-07-2018 11:54 PM
You won't go faster than this. That's the maximum speed you are getting it now with crosstalk, G.INP enabled and SNR 3dB. Unless your cabinet upgraded to g.fast pod soon to get faster for up to 330/50 within 300 metres away from your street cabinet (pcp) if Openreach has planning for your area.
10-10-2018 7:35 PM
Sorry I haven't replied for a while, I wanted to leave the connection alone for a while to let it settle down.
I have been unable to check the router recently as I since moved out, but before I left I'm pretty sure I was getting around 60-65Mbps which was a great improvement.
I could do with checking it again as before i left I was having some issues with Billion router randomly restarting by itself. I'd be interested to see how often that is happening with another one of those connection log things.
Thank you very much for your time!
11-10-2018 11:41 AM
- « Previous
- Next »
