ASUS N55U to Openreach modem
- Re: ASUS N55U to Openreach modem
21-07-2015 11:48 AM
Can anyone give me instructions on the setup of the N55U so I can use it with the Openreach modem, I have looked on here and tried to piece together the info but I must be doing something wrong or missing something as I cannot get it to work
All the steps to move from ADSL to connecting to the OR modem would be great.
Thanks in anticipation
Message 1 of 5
(961 Views)
4 REPLIES 4
21-07-2015 12:38 PM
I don't have any direct experience of this unit myself I'm afraid, but this post seems to suggest that you might need a firmware update http://community.plus.net/forum/index.php/topic,134429.0.html . Once that's done it seems to say that the setup wizard will have the correct settings for PlusNet and all you then need to do is enter your useranem/password ( the same as for ADSL ).
I assume the firmwares are here https://www.asus.com/uk/Networking/DSLN55U_Annex_A/HelpDesk_Download/
Hope that helps
Hope that helps
Message 2 of 5
(631 Views)
21-07-2015 1:13 PM
Thanks, all now working, the wizard did it
For info though you seem to have to be connected to the OR modem before running the wizard.
Message 3 of 5
(631 Views)
21-07-2015 5:13 PM
Very likely. Using the wizard, I would guess that it tries to detect a connection on either the DSL port or the EWAN(Lan port). If the Modem isn't connected then it won't detect a connection on the EWAN port and will (probably) default to the DSL port.
Quote For info though you seem to have to be connected to the OR modem before running the wizard.
Message 4 of 5
(631 Views)
21-07-2015 6:30 PM
I have the 56U with which I am very pleased, I'm sure that you'll be very content.
Message 5 of 5
(631 Views)
