ASUS DSL-N66U v OpenReach Modem
- Re: ASUS DSL-N66U v OpenReach Modem
07-09-2015 2:42 PM
Hello All,
Recently got PlusNet Fibre (moved into an area without Cable) so still new to the whole Fibre over BT OpenReach and all that.
I've got an ASUS DSL-N66U router which has a built in VDSL modem. Am I better off using that or using the modem BT OpenReach gave me then using a normal router connected via Cat5?
I just want a reliable connection; and reading online sometimes using the ASUS router/modem combos can make a slow line / cause issues. So looking for some honest feedback here.
If I do use the ASUS - Is there any specific settings I should enable for the VDSL modem?
Cheers
Cheers
Message 1 of 6
(1,184 Views)
5 REPLIES 5
07-09-2015 5:51 PM
For now I'm assuming you got the openreach modem plugged in, keep it that way and use any router, in a months time or so after you know your connection, then use the asus as a modem and router for a month then compare the pros and cons.
Message 2 of 6
(741 Views)
07-09-2015 9:30 PM
ok will do
Do you think there be in real differences in speed or is that not much in it?
Cheers
Cheers
Message 3 of 6
(741 Views)
08-09-2015 2:05 AM
my experience, no.
Message 4 of 6
(741 Views)
08-09-2015 12:48 PM
More importantly, if you're using the Asus for wifi is by your master socket the best place for coverage in your house. Often it isn't so having the modem on a short lead by the socket and then a long as you like ethernet cable to the router in it's ideal solution would be the best choice.
Message 5 of 6
(741 Views)
08-09-2015 3:22 PM
sound right to me.
Message 6 of 6
(741 Views)
