ASUS DSL-AC68U?
- Re: ASUS DSL-AC68U?
ASUS DSL-AC68U?
28-06-2019 10:18 PM
DSL Firmware Version 1.0.4.7
DSL Driver Version FwVer:5.5.2.10_A_A60901 HwVer:T14.F7_0.2
DSL Link Status
up
DSL Uptime 0 days 1 hours 43 minute(s) 40 seconds
DSL modulation
ITU G.993.2(VDSL2), G.998.4(G.INP)
Regional Mode
A
DSL Exchange (DSLAM)
Broadcom
Current Profile
17a
System Vendor ID
2605443544e00
System Vendor Model ID
00000000000000000000000000000000
Modem Vendor ID
26005443434E5A01
Line Stats
Downstream Upstream
TCM(Trellis Coded Modulation)
On
On
SNR Margin
1.7 dB
5.9 dB
Line Attenuation
11.5 dB
26.2 dB
Path Mode
FastPath
FastPath
Interleave Depth
1
1
Data Rate
52801 kbps
17808 kbps
Max Rate
64988 kbps
17726 kbps
Power
13.2 dbm
7.1 dbm
INP
INP-SHINE
43.0 symbols
50.0 symbols
INP-REIN
1.0 symbols
0.0 symbols
CRC
4
0
VDSL Band Status
U0 D1 U1 D2 U2 D3 U3 D4 U4
Line Attenuation (dB)
2.7
11.5
26.2
34.5
42.3
56.1
Signal Attenuation (dB)
2.7
21.3
26.3
34.3
42.0
54.3
SNR Margin (dB)
6.2
1.3
5.9
0.9
5.9
1.6
Re: ASUS DSL-AC68U?
01-07-2019 2:46 PM
My advice would be to get rid of the Asus DSL AC68U, it is a decent router with good WiFi but the VDSL modem is probably the worst ever and is notorious for causing problems on FTTC services.
The modem circuit has a MediaTek chipset which has a very bad reputation, there are rumours that it may be one of the reasons why G.INP has never been successfully deployed on ECI FTTC equipment.
If you do a bit of searching you will find posts on this forum and others (e.g.Kitz) which confirm the problems with the modem on this device. A lot of users have run it as a Router only with a separate modem such as the Openreach Huawei HG612 3B which works well.
The BT HH6 is pretty good for an ISP supplied device and has the preferred Broadcom modem chipset. So I suggest you put the BT HH6 back on and let DLM do its stuff and see how things go.
