ASUS DSL-AC52U DSL sync problem
denyx
Has anyone managed to connect ASUS DSL-AC52U modem-router on Openreach VDSL?
My router worked fine with ADSL connection, but once account got upgraded to fiber, it can't sync DSL connection.
Tried many different filters etc.
Now just ordered Plusnet's router to try (should have got it right away when ordering the upgrade - derp, lesson learned).
But anything else I could try?
Seasoned Pro
Fixes: 7
Re: ASUS DSL-AC52U DSL sync problem
Check your settings.
I believe they are different on VDSL from ADSL. See
https://www.plus.net/help/broadband/broadband-connection-settings/
denyx
Thanks, went over those suggested settings and the only thing was VLAN part.
Corrected it, but still not working - DSL still can't sync.
Seasoned Pro
Fixes: 7
Ye old fashioned factory reset and then start again with your settings!!!
bill888
Seasoned Pro
Fixes: 24
Check the Annex setting. I think it has to be 'Annex A' on Asus routers to work with Openreach FTTC.
denyx
as previous  poster suggested, i did a reset and it worked.
but you were probably right, and it probably was the annex setting...
thanks all, not it is working and i got 10x download speed increase!
