ADSL speeds using Asus n55u router
- ADSL speeds using Asus n55u router
12-07-2015 10:33 AM
I've just had Plusnet fibre connected, and when using the Plusnet supplied router connecting to the BT fibre modem I get a download speed of 73Mb but when I take out the plusnet router and use an Asus n55u as a router instead, connecting to the BT fibre modem it all seems to work except I only get a download speeds of 15.
Reconnecting the Plusnet router again and it goes back up to 73. Am I missing a setting somewhere which is throttling my speed on the n55u?
Re: ADSL speeds using Asus n55u router
12-07-2015 11:30 AM
12-07-2015 12:29 PM
12-07-2015 12:34 PM
12-07-2015 1:03 PM
I could have given you mine from an ASUS RT-N66U but it has gone faulty.
12-07-2015 1:12 PM
Quote from: MisterW Ok, so that let's out wireless as the issue. I believe the 55u has some fairly extensive QOS settings, have you tried disabling these?
You sir are a genius, give that man a cookie.
I set that up ages ago without really knowing what I was doing. Have now disabled it and have my fibre speeds back AND some good WiFi coverage as well.
Thank you for your help, and everyone else who has posted offering some assistance.
12-07-2015 1:23 PM
A lucky guess really
Quote You sir are a genius
12-07-2015 2:03 PM
12-07-2015 4:26 PM
12-07-2015 4:40 PM
