ADSL Router AND Openreach Modem quick question
- ADSL Router AND Openreach Modem quick question
19-02-2015 1:42 PM
If the PN router supplied proves not to be up scratch with its wireless signal can i use my existing ADSL Netgear D6200 as long as i use the openreach modem with it, until i get an all in one VDSL set up?
Message 1 of 6
(1,030 Views)
5 REPLIES 5
Re: ADSL Router AND Openreach Modem quick question
19-02-2015 1:45 PM
Acording to this page: http://www.netgear.co.uk/home/products/networking/dsl-modems-routers/D6200.aspx it has Ethernet WAN, in which case it would work with the BT modem.
Call me 'w23'
Message 2 of 6
(719 Views)
19-02-2015 2:03 PM
Thanks, do you happen to know what other info other than PN login details, PPPoEalways on and VLAN ID 101, I would need to set up a VDSL router that doesn't have an auto setup, thinking of a TP Link 9980?
Message 3 of 6
(719 Views)
19-02-2015 2:09 PM
This 'Review' on amazon may prove helpful: http://www.amazon.co.uk/review/R270H14ZXIBS4D/ref=cm_cr_dp_title?ie=UTF8&ASIN=B00NEQZ12Y&channel=det...
Call me 'w23'
Message 4 of 6
(719 Views)
19-02-2015 2:16 PM
For the 9980, all you need to do is select PN as the supplier for vdsl, and enter your name/password. The new f/w sets up the vlan automatically.
Message 5 of 6
(719 Views)
19-02-2015 2:20 PM
Thanks w23 and HM, think I'll go for the TP, looking forward to fibre Friday!
Message 6 of 6
(719 Views)
