ADSL Filters
xbeemer66
ADSL Filters
Quick question (I'm new to fibre) - do I need to use ADSL filters for connecting other devices to the phone circuit?
2 REPLIES 2
Fixes: 419
Re: ADSL Filters
If you have a filtered master socket, that's one with both a dsl and phone socket then assuming that any extension cables are correctly connected you don't need to filter any devices plugged into extensions.
If you need to plug a filter in to the master socket to connect to the router then you need to plug them in to any extension socket you use.
xbeemer66
Re: ADSL Filters
Understood!  Many thanks for your advice.
