A temporary solution whilst decorating
- Re: A temporary solution whilst decorating
11-11-2015 4:24 PM
The room the master socket is in is getting re decorated so need to take out BT hub 5 and place elsewhere.
Is it possible to place into an extension socket providing I use a microfilter etc and I remove the filtered faceplate on master socket.
NE
NE
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up
Message 1 of 4
(788 Views)
3 REPLIES 3
11-11-2015 4:29 PM
No need to remove the faceplate, just wire the extension from the unfiltered terminals behind. What model of faceplate is it?
Or are you thinking of a plug-in extension lead? They typically have "flat" (non-twisted-pair) cables that can cause havoc with broadband by picking up interference.
Message 2 of 4
(451 Views)
11-11-2015 5:09 PM
Theres a socket downstairs in the living room
I'm not wiring anything just to move my router for 2 or 3 days
Message 3 of 4
(451 Views)
11-11-2015 11:12 PM
I've removed the filtered faceplate and plugged in router downstairs connected to a micro filter. Seems to work. That's the main concern.
NE
NE
Message 4 of 4
(451 Views)
