turn on suggestions
A small question about the new Plusnet Hub One
- A small question about the new Plusnet Hub One
18-01-2016 9:10 AM
I take it the new Plusnet Hub One is same re delivery as the BT Home Hub is, and doesn't need somebody in for it to be delivered.
Re: A small question about the new Plusnet Hub One
18-01-2016 9:24 AM
Obviously depends on your letterbox
When mine was delivered on 5th Jan the postie did knock and hand it to me - no sig
18-01-2016 9:26 AM
it's designed to fit through letter boxes.. mine however didn't and had to go to the post office to pick it up.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
18-01-2016 9:55 AM
Oh ok cool. Post box should plenty big enough to fit it through. The sorting office isn't far from me mind.
