A router/modem upgrade question
SuperJc
Hello,
Could anyone recommend a better all in one solution than the plusnet hub? I bought an asus dsl n55u but it would not connect no matter what I or plusnet sugessted.
Is the TP Link W9980 any good ?
any suggestions would be appreciated
thank you
Fixes: 62
Re: A router/modem upgrade question
It wouldn't - that is ADSL only
This thread shows the options http://forum.kitz.co.uk/index.php/topic,14436.0.html
Which one depends to a large extent on why the Hub 1 doesn't meet your requirements
SuperJc
Thanks for the info - the tp link one I posted says this -
N600 Wireless Dual Band Gigabit VDSL2/ADSL2+ Modem Router
do I not want that then?
Reason for the change is the wireless is terrible on the hub.
thanks again
Fixes: 62
It won't refers to the asus dsl n55u
I wasn't commenting on the TP Link just advising the options
SuperJc
Ah I see sorry I mis understood. I will stick to whats on the list. I nearly bought a TP link as well. You live and learn
PeeGee
The TD-W9980 is VDSL (as you noted) and is the unit I use for fibre. Cannot really comment on the wireless as I rarely use it (but it works when I do!).
Phil
Plusnet Fibre (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
ProGamerXB1
I have the model on the link, WD T9980 and it's perfect...aside from the fact that plusnet can't handle anyone who has Xbox one , other than that you are fine. It's amazingly stable and is all in one. Just make you go into your account on here and get the PPO3 email and password ( it's your plusnet password ) and then you add this to the setup on the new router . No need to use their terrible standard nonsense and you can also get rid of the big ugly modem they give too Smiley
SuperJc
Thanks for the info. Once Ive sent this one back I may well replace it with the TP-link. I have the hub at present so already lost the modem part but the wireless is dire. I have never had an xbox one problem with plusnet but I do have the console hardwired into the modem..
Thanks again
