A router/modem upgrade question
FIXED- Subscribe to RSS Feed
- Re: A router/modem upgrade question
14-07-2016 1:27 PM
Hello,
Could anyone recommend a better all in one solution than the plusnet hub? I bought an asus dsl n55u but it would not connect no matter what I or plusnet sugessted.
Is the TP Link W9980 any good ?
any suggestions would be appreciated
thank you
Fixed! Go to the fix.
14-07-2016 1:30 PM
It wouldn't - that is ADSL only
This thread shows the options http://forum.kitz.co.uk/index.php/topic,14436.0.html
Which one depends to a large extent on why the Hub 1 doesn't meet your requirements
14-07-2016 1:50 PM
Thanks for the info - the tp link one I posted says this -
N600 Wireless Dual Band Gigabit VDSL2/ADSL2+ Modem Router
do I not want that then?
Reason for the change is the wireless is terrible on the hub.
thanks again
14-07-2016 1:58 PM
It won't refers to the asus dsl n55u
I wasn't commenting on the TP Link just advising the options
14-07-2016 3:01 PM
Ah I see sorry I mis understood. I will stick to whats on the list. I nearly bought a TP link as well. You live and learn
14-07-2016 10:34 PM
The TD-W9980 is VDSL (as you noted) and is the unit I use for fibre. Cannot really comment on the wireless as I rarely use it (but it works when I do!).
Phil
14-07-2016 11:21 PM
18-07-2016 12:09 AM
Thanks for the info. Once Ive sent this one back I may well replace it with the TP-link. I have the hub at present so already lost the modem part but the wireless is dire. I have never had an xbox one problem with plusnet but I do have the console hardwired into the modem..
Thanks again
