A BT guy climbed my pole, and I lost 9Mbps
- A BT guy climbed my pole, and I lost 9Mbps
01-03-2021 7:58 AM
As soon as I got FTTC, I had a rock solid 80Mbps connection. My Modem (VMG8924) even told me 90Mbps was attainable. I'm within spitting distance of the cabinet and can see the exchange from my living room window.
Then one morning, a year or so ago, I saw a BT guy climbing the pole that my line (and other houses' lines) comes from. My connection dropped for a few hours (nice of him to warn us... not!) and when it came back, I had 71Mbps. Damn him!
I've been stuck on that ever since. Which of the following numbers are responsible for that? I'm not that hot on DSL details, but I'm guessing its the SNR margin. Unfortunately I don't recall what the stats were previous to the drop because it had been so stable for so long that I stopped looking. Yes, I've just reset my modem (hence the 1 minute uptime)
VDSL Training Status: Showtime
Mode: VDSL2 Annex B
VDSL Profile: Profile 17a
G.Vector: Disable
Traffic Type: PTM Mode
Link Uptime: 0 day: 0 hour: 1 minute
VDSL Port Details Upstream Downstream
Line Rate: 20.063 Mbps 71.153 Mbps
Actual Net Data Rate: 19.999 Mbps 71.154 Mbps
Trellis Coding: ON ON
SNR Margin: 7.2 dB 6.4 dB
Actual Delay: 0 ms 0 ms
Transmit Power: 6.7 dBm 13.0 dBm
Receive Power: -9.7 dBm -1.3 dBm
Actual INP: 0.0 symbols 48.0 symbols
Total Attenuation: 0.0 dB 14.9 dB
Attainable Net Data Rate: 21.770 Mbps 71.809 Mbps
VDSL Band Status U0 U1 U2 U3 U4 D1 D2 D3
Line Attenuation(dB): 4.6 19.4 30.2 N/A N/A 9.8 23.2 37.2
Signal Attenuation(dB): 4.6 18.6 29.2 N/A N/A 11.0 22.9 37.2
SNR Margin(dB): 7.3 7.2 7.2 N/A N/A 6.4 6.4 6.4
TX Power(dBm): -5.4 -23.8 6.5 N/A N/A 9.5 7.8 7.0
Re: A BT guy climbed my pole, and I lost 9Mbps
01-03-2021 12:17 PM
Our testing isn't showing any issues or anything we can raise to Openreach for investigation and as you're within the speed estimates of your line, I doubt if we booked an engineer visit they'll be able investigate further.
Fingers crossed with time you'll be back on a 80mbps sync.
01-03-2021 12:54 PM
Thanks for your reply. I know it's within the estimate so no one will do anything, that's why I've never bothered asking before (that, and things have taken my mind off the issue until recently).
It's not going to change now; it's been stuck like this for a year and the modem has been restarted enough times.
When I posted, I was thinking I could do things like tweak the SNR margin from this end. Then I discovered that's not possible with FTTC.
I wish I had thrown rocks at him and knocked him off the pole!!!
01-03-2021 1:16 PM
01-03-2021 6:48 PM
Yes it is, if you have a suitable modem.
I use it too eek out an extra 1mbs on my pathetic sub Superfast 24Mbs service.
You need to lookup why FTTC is a feeble system, its really just the laws of physics.
Google attenuation, radio crosstalk.
Why?, he/she did not invent this useless system.
01-03-2021 7:46 PM
@dws1900 which modem do you use?
I definitely read that the SNR margin could not be adjusted on FTTC/VDSL in an article on tweaking it on ADSL. I can't for the life of me find that article again though. I've not found out if my VMG8924 can do it yet. It looks like there are SNR-related settings in the xdslctl command but I'm a bit wary of just trying random things until I find out exactly what they do.
01-03-2021 10:17 PM
I have a Vigor modem, and you can adjust the S/N, which I have done on occasions on my FTTC line.
Typically my S/N is 3-4 db, I have forced it to 2dB with a slight increase in speed, but typically more errors, so more resends and lower through put.
VDSL/ADSL technologies are very susceptible to interference, electrical noise, and line issues (bad joints, water ingress, cross talk). As it is using a radio signal this is to be expected.
FTTP does not suffer as much, shame it did not get adopted twenty years ago.
02-03-2021 2:29 PM
Those SNR tweak options only apply to ADSL by the way, they don't do anything on VDSL connections.
02-03-2021 2:35 PM - edited 02-03-2021 2:41 PM
vdsl snr [delta]
delta: SNR margin delta. The SNR margin delta should range from -50 to 50.
delta=1 means 0.1dB.
Current VDSL SNR Margin is 4 dB.
Current VDSL SNR Margin delta setting is 0.
02-03-2021 6:37 PM
re Those SNR tweak options only apply to ADSL by the way, they don't do anything on VDSL connections.
Please supply evidence of this claim.
02-03-2021 8:37 PM
Openreach themselves. It's handled entirely by the DSLAM for VDSL connections.
03-03-2021 3:57 AM
That is what I read; that the DSLAM can't be overridden.
I've just come back here to say that I've tried with my Zyxel, which seems to have the correct commands, but it made absolutely no difference. I'm uncertain whether the Zyxel is trying to change VDSL settings, or only changing ADSL settings despite using the xdslctl commands. I did notice that changing the SNR margin only changed the resulting config output in the "ADSL-training" parameter, not where I expected. Changing the Max speed parameters instead of directly changing the SNRM had similar zero effect.
I give up. Whatever that BT guy did a year ago, it cost me 9Mbps. I'm tempted to prove my statement of "within spitting distance of the cabinet" from the bottom of my drive!
At least I found a firmware to enable baby jumbo frames, and got an extra eight bytes of MTU on my HE IPv6 tunnel. Yay 🙄 that'll really make up for the lost 9Mbps.
03-03-2021 7:11 PM
That is not evidence, it is a statement, which needs backing up with verified documentation.
03-03-2021 8:53 PM
Good luck getting Openreach's official technical documentation then.
03-03-2021 9:45 PM
If it helps I can confirm that the DLM settings (SNR etc) for FTTC are handled by Openreach at the cabinet.
Unlike ADSL where DLM’s at the exchange and we have a fair bit of control, neither ourselves nor BT Wholesale can change the SNR of FTTC lines.
I’ve never tried as I don’t have a capable modem to change the SNR settings but I’d be surprised if you could do this yourself on an FTTC line.
Having said that, if someone’s tried it and it’s worked then I can’t argue with that
