9th april speed problems again
- 9th april speed problems again
09-04-2016 6:43 PM - edited 09-04-2016 7:06 PM
on ptn-ag04 gives
www.thinkbroadband.com/speedtest/results.html?id=146022681220818889302
the attached was the loss I noticed on pcl-bng02 which promted me to gateway hop too the above ptn-ag04
I can see a night of gateway hopping is due
edit: useless forum code removed the attachment
FTTP 500 regrade from Tues 28th November
Message 1 of 2
(510 Views)
1 REPLY 1
Re: 9th april speed problems again
09-04-2016 9:32 PM
You need to hop on to a ptn-bng, I've been on once since installation and it's never let me down speed or latency wise.
Good luck hopping
Good luck hopping
Raspberry Pi enthusiast!
If you Like it, give it a
Message 2 of 2
(465 Views)
