80Mb service running at 40Mb
dpullen
I don't know if anyone else is having this issue, but I've just noticed this evening my downloads seemed to be capped at 40Mb. Sure enough, with further tests it won't go above 40Mb. Upload speed is almost fine at about 16-17Mb, but download speed is stuck quite firmly at 40Mb.
It was fine yesterday - mid afternoon Saturday.
I reset the router first, then the BTO modem.
I then went to raise a ticket and one of the tests on the Plusnet ticket raising tool asked to pick up a phone listen to the dialtone and there was some crackling which I've not heard before. So a call to BT to raise a line fault and a test later I receive a call saying it's a known fault and the issue should be fixed by Oct 16th!
Re: 80Mb service running at 40Mb
What are your line estimates here - http://www.dslchecker.bt.com/ ?
If you run the BT Speed Tester (http://speedtest.btwholesale.com/) and then the Further Diagnostics, what's your IP Profile?
Fixes: 78
Cheers for the update about the line fault.
After that's been fixed (and I hope it is ASAP!) your speeds should improve over the following few days.
 Adam Walker
dpullen
I've just downloaded a Ubuntu ISO and it started off at a steady 3Mbit and ended up in the last minute of it downloading peaking at 8.1MByte. So it's about normal Smiley This was within 10 minutes of resetting the BTO modem and router.
The Speedtest attachment shows a low speed, but it should hopefully build up in good time. The ping is usually 15ms or thereabouts though :-/
Try this speed test - http://www.thinkbroadband.com/speedtest.htm
The BT Speed Tester is not via reliable for ping response times. I have very low pings, yet the BT Speed Tester shows 30-40ms for me normally.
dpullen
Hmm.. back to very slow speeds again...
2Mb down.
dpullen
See attachment.
Fixes: 62
I may be completely off track here but what does this say about Current Line speed https://portal.plus.net/my.html?action=data_transfer_speed
Also, are you running the tests via a wired or wifi connection ? It can make a huge difference.
dpullen
Current Line Speed: 77.6 Mb. All tests are done wired.
Fixes: 78
@dpullen
I've just replied to your fault ticket, glad to see your connection speeds were much better last night.
Any further problems today please have a look at my reply to the ticket and get back to us.
 Adam Walker
