80MB FTTC install, which modem?
- Re: 80MB FTTC install, which modem?
30-12-2014 9:41 PM
Just signed up to the 80MB Fibre Extra package with phone line (nice Fibre discount plus £150 Quidco cashback!) as my Fibre cab has just been enabled in the last couple of weeks, coming from TalkTalk LLU ADSL2+ (well with XILO not TalkTalk directly but TalkTalk equipment in the exchange)....fingers crossed there wont be a hiccup on install being on LLU at the moment!
Anyway i have an Asus RT-AC68U router (N, AC, 2.4GHz, 5GHz) so will be plugging a fibre modem into that, currently using a Netgear DG834GT in modem mode plugged into the WAN port on the Asus.
As BT are coming to install the fibre faceplate and test the connection i assume they give me a Fibre modem and if so what model is it?
Just wondering if its worth keeping or buying something prior you see!
Sorry for the long winded post.
30-12-2014 9:50 PM
31-12-2014 3:55 AM
The HG612 can be reflashed to make the statistics visible, if you aren't intimidated by that idea; the ECI can only be made more open with soldering. Otherwise pre-hacked HG612's are available from ebay.
Replacing the features of the Asus with something comparable plus VDSL2 support will be expensive; the current Asus model that includes VDSL2 seems to be not well liked by its users.
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
31-12-2014 11:00 AM
Does Fibre require a login and password and if so will I get them from Plusnet at some point?
31-12-2014 12:42 PM
Id is usually of the form "username@plusdsl.net", where the username is the same as used to get onto the portal. Password is the same too.
31-12-2014 12:49 PM
31-12-2014 2:45 PM
Yep my current adsl setup is pppoe with username and password.
Edit
Do the BT supplied modems default to 192.168.1.1?
31-12-2014 3:50 PM
31-12-2014 5:04 PM
31-12-2014 5:20 PM
16-01-2015 1:54 PM
I might buy another HG612 and unlock it, although i'm happy with the fibre so far 24 hours in and have no reason to need it at the moment;
Having been on LLU with no DLM / IP Profiles for a number of years what is the best way of disconnecting the modem/router from the connection/sync to avoid any DLM problems on Fibre?
16-01-2015 2:05 PM
16-01-2015 2:16 PM
16-01-2015 2:49 PM
16-01-2015 2:51 PM
it is an older bcm chipset, only firmware updates are when openreach release, syncs a bit lower, and you need to use a 2nd lan cable for stats.
