80/20 fibre extra but getting 12/15
- 80/20 fibre extra but getting 12/15
- « Previous
- 1
- 2
- Next »
Re: 80/20 fibre but getting 12/15
18-04-2016 11:08 AM
Whilst I agree with your view, unfortunately shouldn't is not equivalent to doesn't
18-04-2016 12:14 PM - edited 18-04-2016 12:34 PM
It looks as though my issue has kinda sorted itself out. Well I'm getting better speeds than before.
I'm now getting 55/18 and the only thing I can see that has changed is the Path Mode from "Fastpath" to "Interleaved". Any ideas on how this would've change by itself?
Also do you think I should be seeing more speed than this? The member centre shows this:
BT wholesale says "61.76 Mbps Max Achievable Speed"
18-04-2016 3:18 PM
Too many errors on the line is the most likely cause. Do you have any other phone sockets or is that master the only one? Can you hear any noise on the line when using the phone?
- « Previous
- 1
- 2
- Next »
