80/20 fibre extra but getting 12/15
Dtx3
I know we're suppose to wait 10 days for the line to settle but surely I should be seeing more than the attached?
17 REPLIES 17
rongtw
Fixes: 12
Re: 80/20 fibre but getting 12/15
There is no 10 day training period on Fibre , hope some PN staff will check this for you ,
or try to restart your router
Dtx3
Oh!
Well in that case there is definitely an issue.
Oldjim
Resting Legend
Fixes: 63
first thing to check is the Plusnet Current Line Speed and the BT IP profile - see sticky at the top of this board https://community.plus.net/t5/Fibre-Broadband/Fibre-Speed-Faults/m-p/1270253#U1270253
MatthewWheeler
Fixes: 479
Can you test it in the next 15 minutes?
 Matthew Wheeler
Dtx3
Yes I'm available to test.
This is my latest.
SpendLessTime
Fixes: 86
Did you log onto the router, click the disconnect button and reconnect before running the BTW speed test?
This would allow the router to pick up the new Plusnet line speed.
Dtx3
Yes I've tried rebooting numerous times.
SpendLessTime
Fixes: 86
I'd log a fault if I was you as something has fixed the download speed to an ADSL speed while setting the upload speed to the FTTC expected value.
 Log a Fault Here
Dtx3
See attached.
"Your service was found to be performing poorly.
Please raise a fault with your service provider, stating that the BT Performance Tester tool indicates poor service throughput performance after the third test."
2016-04-17 09_38_05-ASUS DSL-AC68U Dual-Band Wireless-AC1900 Gigabit VDSL2_ADSL2+ Modem Router - DSL.png
jordanc1230
The router stats show your connecting at 70 Mbps which means it could be a problem at your end. have you carried out the test via ethernet? you should have opted for a hub one so you could have used it to rule out your router being at fault.
Anotherone
Champion
Fixes: 21
What Modem/Router or Modem and Router are you using?
What type of phone line sockets have you got, how many, and what's connected where?
Dtx3
I'm using the Asus dsl-ac68u and this is how I have it connected.
PeeGee
The picture suggests you are testing via wireless, which is the easiest way to get erroneous results. The only way to get consistent accurate results is to use a cable (ethernet) connection.
Phil
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Anotherone
Champion
Fixes: 21
If you are close enough to the Asus, a wireless connection shouldn't have a great impact, but always good to test wired.
Is your computer's wireless drivers up-to-date? Also check out your wireless settings in case there is anything obvious there.
