5ghz wifi freezes, 2.4 is fine. Pulling my hair out now.
- 5ghz wifi freezes, 2.4 is fine. Pulling my hair ou...
- « Previous
- 1
- 2
- Next »
Re: 5ghz wifi freezes, 2.4 is fine. Pulling my hair out now.
26-12-2018 5:10 PM
@andykate66 wrote:
it's just a pain when I've spent so long setting up and naming everything on my network.
Can't you export the configuration, reset the router then re-import. That should reset the router to factory setup then bring back your tweaks.
Unless of course it's one of the tweaks that's causing the problem.
26-12-2018 5:28 PM
I could give that a go, cheers. Pretty much since I started this thread, the 5ghz side of things have held out fine, I did mess about with the Sony tv settings though, WiFi and Bluetooth. It's wired but uses WiFi fo location and I turned the voice search off as I never use it. Maybe that was the culprit...... 🙄🙄
I'm going to leave the hard reset for now and monitor what happens because right now it's perfect again. I will update if I find anything out though.
Cheers for all the input.
Message 17 of 18
(643 Views)
26-12-2018 5:50 PM
Thanks @andykate66, let us know how you get on.
Message 18 of 18
(636 Views)
- « Previous
- 1
- 2
- Next »
