5ghz speed half of 2.4ghz - please help
- 5ghz speed half of 2.4ghz - please help
17-01-2021 12:58 AM
I have been getting a fairly week signal strength in some parts of my house with my hub one router.
I can normally get around 45 to 50mbps - when fairly close to the router, which is fine.
So following feedback from various threads I have split the signals to both 2.4 and 5ghz.
Now even next to the router I get the same 45 to 50mbps on 2.4ghz but struggle to get over 20mbps for 5ghz.
Not a missive issue as the 2.5ghz speed is ok, but I would like to get the 5ghz up.
Have tried playing with various channels with no real difference.
Any advice would be much appreciated.
Re: 5ghz speed half of 2.4ghz - please help
17-01-2021 1:47 PM
@philmo1 Welcome to the forum.
You could add your problem to this thread where it stands a better chance of getting picked up https://community.plus.net/t5/My-Router/Throughput-issues-5ghz/m-p/1735734#M18667
17-01-2021 2:54 PM
