5ghz Connection
Golig1a
Just browsing
5ghz Connection
I recently complained due to very slow speeds and connectivity issues. Tech support took me through setting up the 5ghz and it was fine for a while, it’s suddenly stopped working and no other channel will work. Devices connect but there is no signal. Thanks
1 REPLY 1
Gel
Aspiring Champion
Fixes: 26
Re: 5ghz Connection
Some devices do not have 5ghz connectivity option.
Regards your speed, what happens when you connect a device via network cable ie a LAN connection?
5ghz is faster than 2.4 band, but has less transmission range.
D/load a free wifi analyser programme to ensure channels you're using are
not also being used by your neighbours- pick the least used channels, or preferably an unused one-
you'll have greater channels choice on 5ghz.
