5ghz Connection
- Re: 5ghz Connection
5ghz Connection
23-09-2020 6:15 PM
I recently complained due to very slow speeds and connectivity issues. Tech support took me through setting up the 5ghz and it was fine for a while, it’s suddenly stopped working and no other channel will work. Devices connect but there is no signal. Thanks
Labels:
Message 1 of 2
(349 Views)
1 REPLY 1
Re: 5ghz Connection
23-09-2020 8:22 PM
Some devices do not have 5ghz connectivity option.
Regards your speed, what happens when you connect a device via network cable ie a LAN connection?
5ghz is faster than 2.4 band, but has less transmission range.
D/load a free wifi analyser programme to ensure channels you're using are
not also being used by your neighbours- pick the least used channels, or preferably an unused one-
you'll have greater channels choice on 5ghz.
Message 2 of 2
(328 Views)
