582n router dropping WAN on wifi
- Re: 582n router dropping WAN on wifi
07-11-2014 9:14 PM
Hi everyone
Recently, my router TG582n has started a wifi problem
devices connected wirelessly cannot connect to the WAN (internet/email etc), but can still see and connect to the router itself (I can browse the router menus while on wifi)
the wired pc carries on as normal.
restarting the router or restarting the wifi on the router solves the problem, until the next time.
I've tried a factory reset yesterday, but the wifi problem has happened again today.
(I'm on FTTP, but I'm pretty sure the routers are the same as FTTC & its been fine for over a year so far
any ideas?
GunSmoke
any ideas?
GunSmoke
Message 1 of 5
(980 Views)
4 REPLIES 4
08-11-2014 9:25 AM
Hi gunsmoke,
From what you've mentioned it sounds like a replacement is needed.
I've just arranged that for you so expect that to arrive through the post in around 3 working days time.
Thanks a lot for trying what you can before posting.
Message 2 of 5
(537 Views)
08-11-2014 10:54 AM
Sounds like loss of DNS to me.
Message 3 of 5
(537 Views)
08-11-2014 11:52 AM
It could be, but I wouldn't expect restarting the WiFi to fix it or wired devices to be unaffected if so.
Anyway, next time it happens, you could try to ping 212.159.6.9 or ping 8.8.4.4 from a command prompt.
Message 4 of 5
(537 Views)
08-11-2014 1:47 PM
Depends if it was skype, or just cached pages etc... I'm with your thoughts though, pinging something on the wan side will rule that out.
Message 5 of 5
(537 Views)
