50% speed
offtrolley
50% speed
Past couple of days the speed has been fluctuating:
9mb, 5mb, 16mb
BT Speedtest
 Download speedachieved during the test was - 18.99 Mbps
 For your connection, the acceptable range of speedsis 20 Mbps-38.71 Mbps .
 Additional Information:
 IP Profile for your line is - 38.71 Mbps
Is this the best my Fibre upgrade can achieve?
Fixes: 167
Re: 50% speed
With a profile of 38.71 I'd expect you to see faster speeds. Let me go double check your account.
 Chris Parr
 Plusnet Staff
Fixes: 167
Re: 50% speed
Everything is set correctly on your account, however it doesn't look like you've disconnected/reconnected since upgrading to fibre. Can you try that and see what speeds you're getting.
 Chris Parr
 Plusnet Staff
offtrolley
Re: 50% speed
After re-connect:
6.75 (mbps)
1.44 (mbps)
40.75 (ms)
Fixes: 167
Re: 50% speed
Is that over wired or wireless?
Can you the BT Speedtest http://speedtest.btwholesale.com/ - doing the further diagnostics after the first one?
 Chris Parr
 Plusnet Staff
offtrolley
Re: 50% speed
BT Speedtest keeps taking me to "Third Test" and asks me to change my router login
offtrolley
Re: 50% speed
. Best Effort Test: -provides background information.
  Download Speed
  1.06 Mbps
0 Mbps 38.71 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 1.06 Mbps
  Upload Speed
  1.83 Mbps
0 Mbps 2 Mbps
Upload speed achieved during the test was - 1.83Mbps
 Upstream Rate IP profile on your line is - 2 Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
Fixes: 167
Re: 50% speed
If that's over a wired connection I'd advise getting a fault reported at https://faults.plus.net
 Chris Parr
 Plusnet Staff
