5 months of stability now resets at very low speeds each day
chubsta
Joined PN back in March, very happy with it, consistently high speeds around the 60Meg mark, no issues or disconnects at all - in fact until a week ago I had uptime of over 40 days if I recall correctly.
However, for some reason my connection now resets each day late morning, and usually comes back up with a much lower sync speed but a far higher SNR, today it dropped from 59000+ to 11000, and the SNR jumped from 6 to 21!
Each time I realise this has happened I reboot the outer and it comes back up at around 60000 with an SNR of 6, only for the whole thing to happen again the next day - anyone got any ideas why this would be happening? My setup is very simple with the router plugged directly into the master socket and no other things connected. My connection is lovely and fast and stable with pings around 7ms and a stable SNR so cant work out why it is disconnecting and then syncing at much lower speeds, but then syncing at normal speeds if I reboot the router!
Any and all advice appreciated as it is starting to annoy me...
1 REPLY 1
chubsta
Re: 5 months of stability now resets at very low speeds each day
it has done it today and although the download is as usual at 60meg, the upload is now 0.4meg!
