40/20 to 55/10
oldjack
40/20 to 55/10
Early August Plusnet reduced my upstream to 10 from 20. Advising that the new contract would eventually be 55/10. No problem until i found that I could no longer achieve more than 40 downstream. Called in OR ,engineer 1 confirmed that my line would only achieve 40 (aluminium 10 pair) not happy that he OR didn't report the cable situation to Plusnet so Engineer 2 was called in. A more enlightened chap who together with myself  located a redundant copper 10 pair and rerouted my local cable through it.  Speed at home socket 55/10. Requested Plusnet to modify their sync. to 55/10 and amend distance to cabinet to 465 Mtrs. Last ticket message from Plusnet said I could only have 40 downstream unless I change my contract to 80/20 Huh?. What has happened to my 55/10? Do I have to add this complaint to Ofcom's growing list?
Fixes: 205
Re: 40/20 to 55/10
You should be on 55/10.
As you're on the new network and don't appear to have a static ip, your account shouldn't be capping the download speed.
Just to confirm, are you currently still getting the 10Mbbps upload, or at least above 2Mbps?
I've escalated the ticket on your account to myself.
 Harry Beesley
oldjack
Re: 40/20 to 55/10
Owe you my thanks Harry. My upstream speed varies between 7-9 Mbps so upstream profile of 10 Mbps seems to be the case.
Downstream anything from 22 Mbps to 36 Mbps.
                                       Jack
oldjack
Re: 40/20 to 55/10
Info only. No improvement yet Harry.
Fixes: 205
Re: 40/20 to 55/10
I got in to work 10 minutes ago and my shift started literally 1 minute ago.
I'm looking in to it now. Thanks for your patience.
 Harry Beesley
Fixes: 205
Re: 40/20 to 55/10
Further to my previous reply, I've been advised it should hopefully be resolved within the next half an hour.
I hope that helps.
 Harry Beesley
oldjack
Re: 40/20 to 55/10
Thanks Harry..I hope you don't think I was pressuring you, that wasn't my intention, I was just trying to keep you up to date.
oldjack
Re: 40/20 to 55/10
Okay Harry downstream 51.2 and upstream 7.8 so all is good many thanks
Fixes: 205
Re: 40/20 to 55/10
Glad to hear that's sorted now. Thanks for confirming Thumbs Up
 Harry Beesley
Fixes: 176
Re: 40/20 to 55/10
Moderator's note by Dick (Strat) Fix changed to @HarryB.
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
