40/10 really slow in evenings & weekends
- 40/10 really slow in evenings & weekends
03-03-2018 7:20 PM
For the last six weeks or so our fibre speeds have been terrible at nights and weekends.
From 40meg DL during quieter times in the day, to below 2meg at nights and weekends.
Weeks of back & forth with customer support isn’t getting far - they say everything is fine, while it’s most certainly not.
Can someone please help me? 😊
Re: 40/10 really slow in evenings & weekends
03-03-2018 7:56 PM
i have exact same issue
03-03-2018 8:23 PM
Have you considered running a 24/7 monitor such as JD's Auto Speed Tester to demonstrate the speed differences you are getting?
This is my monitor for last month which fortunately shows no issues but using graphs such as this can help prove your case.
03-03-2018 9:26 PM
Wired connection shows same pattern, and somdod the BT wholesale speed test.
It’s been going on for weeks.
Plusnet customer support are offering to send out an engineer now, but I’m not convinced there’s anything wrong with the wiring - looks like a crowded network issue.
on 04-03-2018 2:58 PM - last edited on 04-03-2018 6:06 PM by Mav
Superuser citation
This topic has been cited by one of the Superusers; the purpose of which is to provide a note for information which might help to focus continued discussion (but might not result in a staff response).
Moderator's note by Mike (Mav): Removed quote mark.
05-03-2018 11:36 AM
05-03-2018 1:06 PM
@Arabdeen wrote:
Here’s a history from my phone WiFi speed check app.
Wired connection shows same pattern, and so does the BT wholesale speed test.
@MatthewWheeler Is this another Hot VLN / Exchange capacity problem?
05-03-2018 1:52 PM
Here was the wired BT Wholesale result.
Thanks,
Iain
06-03-2018 11:01 AM
08-03-2018 8:31 PM
10-03-2018 1:14 PM
15-03-2018 4:06 PM
