4 hours of speed
col6
4 hours of speed
Got connected today to fibre had to ring support to get things working as they should , so worked great for 4 hours now for some reason the download speed has died but the upload is smoking hot
Anyone know why this would happen ?   before and after links below
http://www.speedtest.net/my-result/5322798615
http://www.speedtest.net/my-result/5323256340
SpendLessTime
Aspiring Hero
Fixes: 53
Re: 4 hours of speed
What does the Plusnet Line speed at https://portal.plus.net/my.html?action=data_transfer_speed show ?
It may have gone back to ADSL speed so needs Plusnet to change it and then you need to log onto the router, click "disconnect", wait 30 seconds and then click "connect"
To get Plusnet to change it, either phone or use the Chat facility. Word of warning, if you use adblocker software, you will need to disable for Plusnet sites to get the chat to work.
MattyC
Champion
Fixes: 46
I believe we have this fixed now?
Matty
