30-50% speed drop between sync speed and wired device tests
- Re: 30-50% speed drop between sync speed and wired...
02-03-2018 8:37 PM
Hi, we were upgraded this week on to a new fibre FTTC service. We are getting a clean 56MB plus sync speed on our router (both the Hub One and my old BT Home Hub 6) which is a marked improvement on the 9.44mb sync we used to get on ADSL!
However, using a wired connection without any other devices connected, the max I can seem to get the Ookla speediest to run at is 40.1Mb. I don't understand why there is such a huge drop between my sync speed and my clean test speed.
Could anybody help? The BT wholesale checker is giving me inconsistent results ranging from 15-59mb, yet the sync speed has remained constant.
Thanks!
Re: 30-50% speed drop between sync speed and wired device tests
02-03-2018 10:11 PM
Stupid question perhaps but you are on the 80/20 rather than 40/10 service?
There have been reports of getting different results with different browsers. Worth trying a different one?
02-03-2018 10:14 PM
02-03-2018 10:15 PM
06-03-2018 3:00 PM
