2704n wont change wifi channel
voyager98
I recently had a regrade from ADSL to Fibre and before I used a different wifi channel as have a busy street where I live for wifi.
I Ive tried setting the channel from 1 to 5 on my router and pressed apply and all seems well. When I go the the helpdesk section the channel says 5.
But
When I do a scan of my wifi it is being picked up as on channel 1. Where I am that congested.
Any advice as to make my router set itself the the right channel its saying its on in the setting but not broadcasting in.?
1 REPLY
Estragon
Re: 2704n wont change wifi channel
Have you tried a reboot of it?
