2704n wont change wifi channel
- 2704n wont change wifi channel
31-07-2015 6:34 PM
I recently had a regrade from ADSL to Fibre and before I used a different wifi channel as have a busy street where I live for wifi.
I Ive tried setting the channel from 1 to 5 on my router and pressed apply and all seems well. When I go the the helpdesk section the channel says 5.
But
When I do a scan of my wifi it is being picked up as on channel 1. Where I am that congested.
Any advice as to make my router set itself the the right channel its saying its on in the setting but not broadcasting in.?
But
Message 1 of 2
(552 Views)
1 REPLY 1
Re: 2704n wont change wifi channel
01-08-2015 11:50 PM
Have you tried a reboot of it?
Message 2 of 2
(333 Views)
