2704n router
- 2704n router
2704n router
02-03-2015 4:40 PM
Hi
Is there anyway to block sites / urls on the Plusnet router 2704n, if not is the Netgear N600 compatible with Plusnet fiber ?
Message 1 of 3
(574 Views)
2 REPLIES 2
Re: 2704n router
02-03-2015 4:44 PM
If the 2704n doesn't allow you to, you can use OpenDNS (free service) - https://www.opendns.com/home-internet-security/parental-controls/opendns-home/
Message 2 of 3
(282 Views)
Re: 2704n router
02-03-2015 4:55 PM
Thanks will have a look.
Message 3 of 3
(282 Views)
