2.4ghz verses 5gz wireless
- 2.4ghz verses 5gz wireless
12-05-2016 6:08 PM
have just received a new hub one from pn and noticed that i have two wireless channels can someone explain the difference between the two and also how the router goes about choosing which channel it assigns to your device cheers tonyt
Re: 2.4ghz verses 5gz wireless
12-05-2016 6:25 PM
The 5Ghz band has shorter range, but is less prone to interference and you'll tend to get your full speed on this.
A good idea is connect your compatible devices to both and allow them to roam between as the signal strength changes
12-05-2016 6:28 PM
much appreciated paul for the quick reply looking at the activity between the two it does appear to be doing just that so i think i will just leave it alone and let each device choose its own frequency
24-05-2016 10:37 AM
5Ghz doesn't penetrate solids as well as 2.4GHz, so it doesn't go through walls as well
