2.4 ghz WiFi gone
FIXED- Subscribe to RSS Feed
- Re: 2.4 ghz WiFi gone
27-12-2020 9:20 PM
5 ghz working, but devices that can’t connect to 5ghz and need 2.4 can’t. Password checked, setttings checked and enabled, software version 4.7.5.1.83.8.263
Had nothing but trouble since we moved to plusnet around a year ago.
Please can someone help?
Fixed! Go to the fix.
27-12-2020 9:23 PM
Have you tried changing the wireless channels? Also try a factory reset of the router using the pinhole at the back. You’ll need to desync the frequencies again after
27-12-2020 9:40 PM
Thanks for the quick response, tried a couple of channels but no joy. Will try the rest tomorrow, then the factory reset if that fails - cross your fingers!
28-12-2020 11:57 AM
Thanks Thrall, reset the hub, then I connected the 3 devices that need 2.4ghz. When they were connected I split the two and changed the name of the 5ghz. It seems to have done the trick.
