(11836.110000) PPP LCP Send Termination Request [User request] had this twice today
- (11836.110000) PPP LCP Send Termination Request [U...
01-05-2018 5:34 PM
17:18:43, 01 May. | (11978.810000) Admin login successful by 192.168.1.73 on HTTP |
17:18:07, 01 May. | (11942.830000) PTM over DSL is up |
17:17:39, 01 May. | (11914.830000) Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any->65477, internal ports: 65477, internal client: 192.168.1.73 |
17:17:27, 01 May. | (11903.410000) PTM over DSL is down after 0 minutes uptime |
17:17:18, 01 May. | (11894.020000) Port forwarding rule deleted via UPnP/TR064. Protocol: UDP, external ports: any->63028, internal ports: 63028, internal client: 192.168.1.73 |
17:17:01, 01 May. | (11876.980000) PTM over DSL is up |
17:16:56, 01 May. | (11872.180000) CWMP: session closed due to error: Could not resolve host |
17:16:56, 01 May. | (11872.120000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
17:16:56, 01 May. | (11872.110000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE' |
17:16:25, 01 May. | (11841.740000) CWMP: session closed due to error: Could not resolve host |
17:16:25, 01 May. | (11841.310000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
17:16:25, 01 May. | (11841.300000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE' |
17:16:25, 01 May. | (11840.970000) CWMP: Initializing transaction for event code 4 VALUE CHANGE |
17:16:23, 01 May. | (11839.040000) PTM over DSL is down after 30 minutes uptime |
17:16:23, 01 May. | (11839.040000) PPPoE is down after 29 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 - Down)] |
17:16:20, 01 May. | (11836.110000) PPP LCP Send Termination Request [User request] |
Re: (11836.110000) PPP LCP Send Termination Request [User request] had this twice today
01-05-2018 8:58 PM
and again
20:53:42, 01 May. | (24878.620000) Port forwarding rule deleted via UPnP/TR064. Protocol: UDP, external ports: any->63028, internal ports: 63028, internal client: 192.168.1.73 |
20:53:40, 01 May. | (24876.010000) Admin login successful by 192.168.1.73 on HTTP |
20:53:23, 01 May. | (24859.510000) CWMP: session completed successfully |
20:53:23, 01 May. | (24859.320000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo |
20:53:15, 01 May. | (24851.760000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
20:53:15, 01 May. | (24851.750000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE' |
20:53:13, 01 May. | (24849.700000) WAN operating mode is VDSL |
20:53:13, 01 May. | (24849.700000) Last WAN operating mode was VDSL |
20:53:12, 01 May. | (24848.050000) PPP IPCP Receive Configuration ACK |
20:53:12, 01 May. | (24848.010000) PPP IPCP Send Configuration Request |
20:53:12, 01 May. | (24848.000000) PPP IPCP Receive Configuration NAK |
20:53:12, 01 May. | (24848.000000) PPP IPCP Send Configuration ACK |
20:53:12, 01 May. | (24847.990000) PPP IPCP Receive Configuration Request |
20:53:12, 01 May. | (24847.990000) PPP IPCP Send Configuration Request |
20:53:10, 01 May. | (24846.550000) PPPoE is up - Down Rate=39993Kbps, Up Rate=507Kbps; SNR Margin Down=8.5dB, Up=10.1dB |
20:53:10, 01 May. | (24846.530000) CHAP authentication successful |
20:53:10, 01 May. | (24846.480000) CHAP Receive Challenge |
20:53:10, 01 May. | (24846.480000) Starting CHAP authentication with peer |
20:53:10, 01 May. | (24846.480000) PPP LCP Receive Configuration ACK |
20:53:10, 01 May. | (24846.470000) PPP LCP Send Configuration Request |
20:53:10, 01 May. | (24846.470000) PPP LCP Receive Configuration Reject |
20:53:10, 01 May. | (24846.470000) PPP LCP Send Configuration ACK |
20:53:10, 01 May. | (24846.460000) PPP LCP Receive Configuration Request |
20:53:10, 01 May. | (24846.460000) PPP LCP Send Configuration Request |
20:53:02, 01 May. | OUT: BLOCK [17] Access control (UDP [0.0.0.0]:68->[255.255.255.255]:67 on ptm0.101) |
20:52:57, 01 May. | (24833.610000) PTM over DSL is up |
20:52:52, 01 May. | (24828.560000) CWMP: session closed due to error: Could not resolve host |
20:52:52, 01 May. | (24828.540000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
20:52:52, 01 May. | (24828.530000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE' |
20:52:22, 01 May. | (24798.200000) CWMP: session closed due to error: Could not resolve host |
20:52:22, 01 May. | (24798.150000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username |
20:52:22, 01 May. | (24798.140000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE' |
20:52:21, 01 May. | (24797.800000) CWMP: Initializing transaction for event code 4 VALUE CHANGE |
20:52:19, 01 May. | (24794.820000) PTM over DSL is down after 211 minutes uptime |
20:52:19, 01 May. | (24794.820000) PPPoE is down after 211 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 - Down)] |
20:52:16, 01 May. | (24791.880000) PPP LCP Send Termination Request [User request] |
01-05-2018 9:09 PM
So what is it you are trying to achieve?
Posting router logs showing your router has dropped sync is not particularly helpful.
What would be more helpful would be running through the checks in the Help section.
Dial 17070 option 2 from a corded phone. is the line quiet? If not report a voice fault.
What speed is your line capable of? Putting your phone number in the DSL Checker and posting the results.
Log into your router and post the results of the Helpdesk tab, making sure you hide sensitive information such as your username.
You will get a lot more meaningful support if people are able to see the results.
01-05-2018 9:17 PM - edited 01-05-2018 9:20 PM
01-05-2018 9:17 PM
01-05-2018 9:21 PM
I generally get 38 mb d/l and around 8-9 upload
01-05-2018 9:38 PM
reboot of router back to normality 37 dl 8 upload....till the next time it does what's it's doing
