(11836.110000) PPP LCP Send Termination Request [User request] had this twice today
LEEEVANS69
17:18:43, 01 May. (11978.810000) Admin login successful by 192.168.1.73 on HTTP
17:18:07, 01 May. (11942.830000) PTM over DSL is up
17:17:39, 01 May. (11914.830000) Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any-​>65477, internal ports: 65477, internal client: 192.168.1.73
17:17:27, 01 May. (11903.410000) PTM over DSL is down after 0 minutes uptime
17:17:18, 01 May. (11894.020000) Port forwarding rule deleted via UPnP/TR064. Protocol: UDP, external ports: any-​>63028, internal ports: 63028, internal client: 192.168.1.73
17:17:01, 01 May. (11876.980000) PTM over DSL is up
17:16:56, 01 May. (11872.180000) CWMP: session closed due to error: Could not resolve host
17:16:56, 01 May. (11872.120000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username
17:16:56, 01 May. (11872.110000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
17:16:25, 01 May. (11841.740000) CWMP: session closed due to error: Could not resolve host
17:16:25, 01 May. (11841.310000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username
17:16:25, 01 May. (11841.300000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
17:16:25, 01 May. (11840.970000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
17:16:23, 01 May. (11839.040000) PTM over DSL is down after 30 minutes uptime
17:16:23, 01 May. (11839.040000) PPPoE is down after 29 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 -​ Down)]
17:16:20, 01 May. (11836.110000) PPP LCP Send Termination Request [User request]
6 REPLIES 6
LEEEVANS69
Re: (11836.110000) PPP LCP Send Termination Request [User request] had this twice today
and again
20:53:42, 01 May. (24878.620000) Port forwarding rule deleted via UPnP/TR064. Protocol: UDP, external ports: any-​>63028, internal ports: 63028, internal client: 192.168.1.73
20:53:40, 01 May. (24876.010000) Admin login successful by 192.168.1.73 on HTTP
20:53:23, 01 May. (24859.510000) CWMP: session completed successfully
20:53:23, 01 May. (24859.320000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo
20:53:15, 01 May. (24851.760000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username
20:53:15, 01 May. (24851.750000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
20:53:13, 01 May. (24849.700000) WAN operating mode is VDSL
20:53:13, 01 May. (24849.700000) Last WAN operating mode was VDSL
20:53:12, 01 May. (24848.050000) PPP IPCP Receive Configuration ACK
20:53:12, 01 May. (24848.010000) PPP IPCP Send Configuration Request
20:53:12, 01 May. (24848.000000) PPP IPCP Receive Configuration NAK
20:53:12, 01 May. (24848.000000) PPP IPCP Send Configuration ACK
20:53:12, 01 May. (24847.990000) PPP IPCP Receive Configuration Request
20:53:12, 01 May. (24847.990000) PPP IPCP Send Configuration Request
20:53:10, 01 May. (24846.550000) PPPoE is up -​ Down Rate=39993Kbps, Up Rate=507Kbps; SNR Margin Down=8.5dB, Up=10.1dB
20:53:10, 01 May. (24846.530000) CHAP authentication successful
20:53:10, 01 May. (24846.480000) CHAP Receive Challenge
20:53:10, 01 May. (24846.480000) Starting CHAP authentication with peer
20:53:10, 01 May. (24846.480000) PPP LCP Receive Configuration ACK
20:53:10, 01 May. (24846.470000) PPP LCP Send Configuration Request
20:53:10, 01 May. (24846.470000) PPP LCP Receive Configuration Reject
20:53:10, 01 May. (24846.470000) PPP LCP Send Configuration ACK
20:53:10, 01 May. (24846.460000) PPP LCP Receive Configuration Request
20:53:10, 01 May. (24846.460000) PPP LCP Send Configuration Request
20:53:02, 01 May. OUT: BLOCK [17] Access control (UDP [0.0.0.0]:68-​>[255.255.255.255]:67 on ptm0.101)
20:52:57, 01 May. (24833.610000) PTM over DSL is up
20:52:52, 01 May. (24828.560000) CWMP: session closed due to error: Could not resolve host
20:52:52, 01 May. (24828.540000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username
20:52:52, 01 May. (24828.530000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
20:52:22, 01 May. (24798.200000) CWMP: session closed due to error: Could not resolve host
20:52:22, 01 May. (24798.150000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username
20:52:22, 01 May. (24798.140000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
20:52:21, 01 May. (24797.800000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
20:52:19, 01 May. (24794.820000) PTM over DSL is down after 211 minutes uptime
20:52:19, 01 May. (24794.820000) PPPoE is down after 211 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 -​ Down)]
20:52:16, 01 May. (24791.880000) PPP LCP Send Termination Request [User request]
Mustrum
Fixes: 77
So what is it you are trying to achieve?
Posting router logs showing your router has dropped sync is not particularly helpful.
What would be more helpful would be running through the checks in the Help section.
Dial 17070 option 2 from a corded phone. is the line quiet? If not report a voice fault.
What speed is your line capable of? Putting your phone number in the DSL Checker and posting the results.
Log into your router and post the results of the Helpdesk tab, making sure you hide sensitive information such as your username.
You will get a lot more meaningful support if people are able to see the results.
LEEEVANS69
LEEEVANS69
LEEEVANS69
I generally get  38 mb d/l and  around 8-9 upload
LEEEVANS69
reboot of router back to normality  37 dl   8 upload....till the next time it does what's it's doing
