10 days fibre settle connection
swiftz
My Plusnet Unlimited Fibre Extra has activated today and when I signed up to Plusnet, I got this email and was wondering do I need to do the below instructions or just leave the router powered on without disconnecting it?
During the first 10 days of your new service
Once we've activated your broadband we'll run a number of tests on your line from your telephone exchange. These will cause your speeds to go up and down, plus you might get disconnected a few times. Don't worry, this doesn't mean there's a problem. During this time is where we'll find the best balance between speed and reliability for your line. You can help the testing process by rebooting your router (switch it off and on again) three or four times over the first 10 days. You'll get better results if you can do this in the morning.
Fixes: 542
Re: 10 days fibre settle connection
Hello there.
I don't think it makes too much of a difference.
Let us know at the end of the 10 day period and we'll test your line to make sure things are where they should be.
Anoush
Seasoned Champion
Fixes: 10
@Gandalf - I thought the 10 day 'stabalisation' didn't apply to a fibre connection - or have I misread the comments from the likes of Townman and others on this subject?
Fixes: 542
That's a good point. It's usually 3 days actually. I've flagged that up with the relevant team.
rongtw
Fixes: 12
Yes i was led to believe the FTTC settled to its optimal speed  set by the DLM within the first 48 hours
swiftz
At the end of the 3 day period, the line test carried out to make sure speeds are correct is done automatically or do I need to contact somone?
Fixes: 542
I believe we'll send you an email automatically after 14 days to let you know of the current line speed. But feel free to drop us a post back on here too and we'll run a line test to check things out in greater detail.
DaveyH
Seasoned Pro
Fixes: 9
I seem to recall there's actually no active DLM for the first 48hrs after provisioning and it's only after that it becomes active.
Edit - Zen seems to confirm that
https://support.zen.co.uk/kb/Knowledgebase/Fibre-Optic-Broadband-FTTC-What-is-DLM-and-how-does-it-wo...
Browni
Aspiring Hero
Fixes: 48
DLM explained here.
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
