webstats
- Everything else
- webstats
webstats
13-08-2007 11:29 PM
Hi
Does the webstats utility on the FreeOnline portal ignore my own visits to the site?
Message 1 of 2
(2,144 Views)
1 REPLY 1
Re: webstats
14-08-2007 11:03 PM
Yes it will include your visits as the stats use the default configuration so you look exactly the same as anyone else when visiting.
If you want them to exclude you then you will need to setup your own webalizer stats on your ccgi webspace and configure it to exclude your IP.
See the usertools tutorial on how to set-up Webalizer plus the recent thread detailing corrections here. Note: you will need to raise a ticket asking for raw stats to be generated on your account.
Message 2 of 2
(382 Views)
