web pages
- Everything else
- Re: web pages
web pages
29-02-2008 12:09 PM
Re: web pages
29-02-2008 12:16 PM
ps This might be better in Webspace Help, I'm sure a friendly mod will move it.
Re: web pages
29-02-2008 12:17 PM
Please let us know, thanks,
Re: web pages
29-02-2008 12:23 PM
Quote from: Chris ps This might be better in Webspace Help, I'm sure a friendly mod will move it.
Indeed!
It will probably be seen by the web experts if its in this board.
Re: web pages
29-02-2008 12:54 PM
Quote from: josiegrace i have up loaded my web site but i cant get the forms to work i created it in publisher:'( can anybody help me?
The webpage cannot be found
HTTP 404
Most likely causes:
There might be a typing error in the address.
If you clicked on a link, it may be out of date.
What you can try:
Retype the address.
Go back to the previous page.
Go to and look for the information you want.
More information
www.planningpartnership.com
Re: web pages
29-02-2008 1:03 PM
HTTP 404
Most likely causes:
What you can try:
Retype the address.
More information
the error message is
this is my first time on this site so be all the forms are preset into publisher
Re: web pages
29-02-2008 1:04 PM
Found the General response form, and it seems to fill in o.k. but did not submit it....
can give it a "anon" in all boxes and submit if that is any help.....
Re: web pages
29-02-2008 1:15 PM
This is the line that is doing this
<form action=--WEBBOT-SELF-- method=post>
It looks like the form needs frontpage extensions and will not work on the normal www webspace.
Publisher is not a good application to design websites in.
Re: web pages
29-02-2008 1:19 PM
Re: web pages
29-02-2008 1:24 PM
Quote from: Peter When I try using the form and submit it takes me to http://www.planningpartnership.com/index_files/--WEBBOT-SELF--
This is the line that is doing this<form action=--WEBBOT-SELF-- method=post>
hi peter
i think you are so right but i am not a web page designer and i can only use publisher i have activated my front page extention with my account but the form still will not work do you have any idears
Re: web pages
29-02-2008 1:26 PM
Quote from: shutter Have just clicked on the link to www.planningpartnership.com and it came up no problem with me using IE6
shutter
the form is ok it just wont submit any help would be good thanks
Re: web pages
29-02-2008 1:27 PM
Quote from: Peter Also try the website in firefox and opera browsers. The graphics & pictures don't look good and some links do not work.
so what could i do about that then and dont say design it in something eles lol
Re: web pages
29-02-2008 1:27 PM
Having not used publisher I am only guessing about frontpage as it uses webbots for things like forms. I suspect it relies on it being run on a windows based web server but PlusNet us *nix based ones so it would not recognise all the special coding in the page.
Can't help any further. Hopefully someone who does know publisher / frontpage can help.
Re: web pages
29-02-2008 1:37 PM
I used Publisher 98 for my website originally as I didn`t know html (still don`t) but, like you was told that it puts a load of rubbish into the html..... (my orig site had 450 photographs and when uploaded was 150mb) when I re-did it using another program with 500 photographs it was (is 90mb) so you can see how much "rubbish" publisher put in to it....
I was given a link to DreamweaverCS3 which has a horizontal split screen, so you can do your website like publisher in the bottom half, and then it "updates" the html in the top half..... so you can see how the html makes the page and mess about with it....
I will see if I can find the link and send it in a PM for you if you want to try it
Re: web pages
29-02-2008 2:07 PM
Quote from: shutter Hi Josie,
I will see if I can find the link and send it in a PM for you if you want to try it (it`s free)
Hi Shutter
Thanks i do appriciate it yes please send it over
