visitors 'book'
- Everything else
- visitors 'book'
visitors 'book'
27-04-2013 4:37 PM
How can I create a message box that acts as a visitors book (a place where comments can be left) on my website. My editor is the 'outcast', FrontPage. I've tried to create this using FP but as PN doesn't support FP extensions it doesn't work.
What I want is something similar to this message box.
Is this achievable for a novice.
Best regards
Mick
Best regards
Mick
Message 1 of 3
(1,133 Views)
2 REPLIES 2
Re: visitors 'book'
02-05-2013 4:32 PM
Hi Mick,
Unfortunately I think the answer here is that Homepages don't provide the dynamic capability that a visitor's book would need.
The closest approximation is probably to incorporate an Email feedback form on your site. You could manually add emailed comments to the site (as long as the senders are happy for you to publish what they send).
David
David
David
Message 2 of 3
(139 Views)
Re: visitors 'book'
02-05-2013 6:44 PM
Hi David & many thanks for your reply. That's a bit like how i've set it up, but simplier (you know me), with just a link to my email address.
Best regards
Mick
Best regards
Mick
Message 3 of 3
(139 Views)
