using php require function
- Everything else
- using php require function
26-05-2008 3:57 PM
hi
i am trying to recall 2 pages using the php require function
but as u can see from www.stakesbyarmsfc.co.uk it doesnt show up?
Message 1 of 3
(994 Views)
2 REPLIES 2
Re: using php require function
26-05-2008 4:51 PM
Message 2 of 3
(243 Views)
26-05-2008 4:56 PM
If fact, have a look at some of the other ccgi tutorials on this page particularly the ones at the bottom regarding installing ccgi software. Although you probably won't want any of the software, there are important notes there about getting php scripts to run using the chmod instructions and the fixphpperms.sh shell script.
Message 3 of 3
(243 Views)
- Everything else
