unable to access ftp login
- Everything else
- Re: unable to access ftp login
07-02-2008 6:29 PM
But when i try and log into the ftp site, i get password incorrect error and its driving me mad.
Has anybody got any ideas???
07-02-2008 6:49 PM
What webspace are you refering to: www or ccgi
What ftp host are you trying to connect to? for www you use ftp.plus.net, for ccgi you use ccgi.plus.net and both use your normal portal login & password.
07-02-2008 7:14 PM
I am a newly registered broadband user, just waiting for activation.
I can get to loging in via ftp client but will refuse my login details.
07-02-2008 7:22 PM
07-02-2008 7:25 PM
ill wait till then, design it ready offline
07-02-2008 8:27 PM
I've given things a kick at this side. Try again in 4 hours or so. If you're still having problems then, raise a ticket to our support team using the Help Assistant on our website.
07-02-2008 10:48 PM
Poxy Microsoft!
07-02-2008 10:58 PM
On my XP machine if I turn off zone-alarm, I get a message in the bottom bar to say your machine is a risk, you can say s... off and it will.
07-02-2008 11:15 PM
08-02-2008 8:35 AM
08-02-2008 8:41 AM
- Everything else
